Old 04-13-2020, 08:13 PM
RLemke's Avatar
RLemke RLemke is offline
Finally had a brand new set of matching tires mounted on the rear wheels. Then mowed the yard to break them in...
Old 04-16-2020, 07:57 PM
twoton twoton is offline
Time for an overhaul...
Old 04-17-2020, 03:26 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default The Crew
Took the tractors out of the garage and the building out back for a photo shoot. Had to jump start the refurbished one. A lot of compression after the rebuild. Have a battery tender but I had unhooked it and forgot to hook it back. First
149 tractor is the one I refurbished. Second 149 tractor is the one I bought last summer. Had a 50" deck that I gave to my Son in Law. Now has a 38" deck. Neighbor uses it to mow his back yard shown in back ground. Chains and weights and it will go any where. Third 149 tractor is my snow blowing tractor. Rear tires are loaded and does a good job. Last is my simplicity broadmoor (loaded rear tires) that I use on my lawn. It is much easier on this old man.old.Thanks for looking and have a great day.
Bob
Old 04-17-2020, 06:45 PM
That's a nice lineup!
Old 04-17-2020, 10:26 PM
IHCubCadet147's Avatar
Good looking Cubs!
Old 04-28-2020, 06:46 PM
cub123's Avatar
cub123 cub123 is offline
I guess it has been a little while since I have posted. I got the loader out and bagged some sand from along our creek to use on a project. Then i got the super out and mowed the yard.
Old 04-29-2020, 07:52 AM
cooperino's Avatar
Really nice pair of workers ya got there!
Old 05-08-2020, 06:13 PM
Getting there...
Old 05-08-2020, 08:25 PM
three4rd three4rd is offline
Rather unsuccessfully put on a new petcock only to find that it leaks between the threads and the bottom of the tank. One of those simple jobs that is turning out not to be as simple as expected.
Old 05-09-2020, 06:44 PM
jbrewer's Avatar
jbrewer jbrewer is offline
I got a tube to put in the front tire of the smoker. I hate doing these but thought I could just break the bead, and stuff in a tube.
Ha!
As usual, I used my 5000 lb truck and steel service ramps to break the bead. No problem, I've done this before. But....what in holy hades, there's GOOP in here.
Good lord what a runny miserable mess. I broke the other bead (fun on wide rims!) and wrestled the slimy tire off, then went to work getting the semi-hardened slime and rust out of the wheel. I'll finish tomorrow .. the die grinder with the wire wheel makes this go pretty fast to clean.
One simple job leads to.... lots of jobs......
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
