Old 03-12-2015, 04:34 PM
Wbrech Wbrech is offline
Put the two newest tresures on wood duty today. Got a little muddy this afternoon but I'll take it over what we had two weeks ago!
Old 03-14-2015, 09:37 AM
I heard that!
Raining here today, but at least its in the 40's
Great pictures of the Cubs working the fire wood
Old 03-14-2015, 07:48 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Good looking Cubs!!
I hauled a load (hopefully that last one this winter) of wood to the house after I stripped the 1864 of it's winter clothes yesterday.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 03-14-2015, 07:52 PM
Nice pics guys. Hauling wood with a Cub beats using a wheelbarrow.
Old 03-14-2015, 08:32 PM
Shrewcub's Avatar
Thanks,Sam!!
Most of the time I do use the wheelbarrow but that cart is 3 light wheelbarrow loads, so when a cub is running and the cart is hooked, I take advantage!
In the first pic, you can see I don't have but about a 100' run from the shed to the hole in the house, so normally it's not that bad! It sucks the worst when it's muddy!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 03-15-2015, 08:52 PM
C5rider C5rider is offline
Got all the cubs out for a tinkerin' session. I double-checked the charging system on the puller. Turns out carbon on the relay in the regulator kept it from charging properly. a little file work and adjustment and it's up to snuff again.
Got the 70 charging again (had the S/G rebuilt) and tinkered with the relay ground. Other tractors are pretty solid right now, so it was just time to line 'em up for a quick family photo.
Old 03-15-2015, 09:04 PM
jimbob200521's Avatar
Got some spring maintenance done today. Took the cab off the 1864, got the 2284 raised up and the front tires off for the new shoes coming in this week. Adjusted a few things and once I get the new shoes on all around, the deck will go on and I'll be ready for some grass killing!
Also got the oil changed on the 2284, new fuel filter on the 2284 & 1864, test fitted my new bumper (after elongating one bolt hole, it fit like a charm), and a few other busy work tasks. Getting anxious for grass killing!
-Ryan
Old 03-16-2015, 01:34 PM
Inactive Member
Default Cub season!
Got the three cubs out of hibernation. Charged up all three batteries and took them for a little run... The 2072 required a new fuel pump (PITA!! ) and the carb cleaned and new float needle. Now just need to figure out the 982. Group pic!
Old 03-17-2015, 05:08 PM
Got the narrow front 125 out of hibernation and changed the oil, and got rid of the stack and made a short muffle extension. That stack was useless for getting under tree branches while thatching and sweeping the lawn.
Old 03-17-2015, 05:42 PM
Love the Narrow frame look. I'm gonna have to build one soon.
