#8931
Cut the grass with the 1641 today.
grass is green and thick from all the rain.
Up to 534 and counting... I give up updating my profile! |
#8932
I haven't posted for a while , so thought I would post a few pictures of this weeks grass seeding job. I did a little tilling, then some harrowing , then seeding , then some coulter packing . Now just hope the grass seeding grows
#8933
There's 71 years of age between them, but both do a fine job of mowing! As for me, I just turn the wrenches when needed
#8934
I have not been working on the Cubs much lately as I had rotator cuff surgery in May, but I finally got the new 26X12X12 Tru-Powers mounted and loaded with windshield washer antifreeze. The engine had been acting like it was low on power and missing. Took the side cover off and put a wrench on the fitting to bleed the injectors and found the lower fitting which goes into the pump was loose. Insant fix! I was very relieved. I had forgotten how powerful the engine felt when running on all 3 cylinders.I went through the 54 inch mower deck last summer and replaced all the bearings. I had a couple of instances where the deck belt came off. I pulled the deck again last week and found the arm that the idler pulley is attached to had a slight bend in it so I straightened that and it seems to work fine now. It is a nice feeling to get some things done again.
___________________ Jim 782 w/Command 18, 1862 not running; IH 42 inch blade; off brand cart |
#8935
Awesome pics everyone, plenty of good submissions for POTW here if y'all know what I mean
![]() Quote:
-Ryan
#8936
Jimbob I'm not sure I will be able to fit you in this fall , the fall seeding window is shutting fast and I am swamped . I am on the way to an over 100 job season , I haven't started fall plowing yet. I usually plow 25 to 30 gardens in the fall. I can pencil you in on the early spring seeding list if you want .
#8937
Rehabing the 2284. Many hours and dollars on the deck. Slipped it under the tractor tonight, wrestled the belt on, and then trimmed some weeds out of the lawn. Worked well. Next the throttle linkage needs serious attention.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
#8938
Looks good from here!
#8939
Put on the rear mounted (Rear facing), blade and spread some old manure on the garden. Then pushed back some gravel, that had washed down the drive.
Then, put it out front, for sale. (Moving, and have too many)
Steve |
#8940
Mowed some grass with the 1641. Tough job but someone needs to do it. Finally got around to painting the rear wheels Cub White, they were originally JD wheels. Tires needed tubes so it was a good time to get it done. Gotta paint the deck one of these years.
