Old 10-24-2015, 12:11 AM
coakes00's Avatar
coakes00 coakes00 is offline
Didn't get finished with what I started today but I made pretty good progress with an engine swap between a K241 to a K301. The tractor has been sitting for at least 20 years. The old batter was stamped early 1993. I also found out what 20+ years of sitting can to do tires. Swapped them out for fronts from an old Murray and rears from a 123 parts tractor. Made it run, but need some pto parts, new ignition, and some other misc. parts. I'll post more pictures when I get it all buttoned up.
Old 10-24-2015, 02:42 PM
aagitch's Avatar
aagitch aagitch is offline
Got a nice used dash installed from one of the sponsors. Also making headway on converting it back to power steering. Decided to have the axle match the yellow rear before I installed it. Waiting for the rod ends to get here for the cylinder. I replaced one of the hoses (local hose shop) due to major cracking.
Adrian
2072 (789513)
Old 10-24-2015, 08:18 PM
The 1872 is looking good, Adrian! Keep up the good work!
Old 10-26-2015, 10:02 AM
SGragg SGragg is offline
Inactive Member
Default Leaf Hauling
Plowed the garden Saturday with the Farmall Cub and 193 plow. Ground was hard as rock, but turned over.
Mowed Sunday and blew leaves into piles that I hauled over to the garden spot. About 10 loads. The CCC 782 (Kohler K-17 Series II) worked well. Glad to have it all done before colder weather moves in.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 10-27-2015, 07:56 PM
aagitch's Avatar
Worked on putting the 1872 back together. I was going to post a pick but instead I'm posting a pic of what my son worked on. I was at the 1872 and looked up and he he had put Mater on the jack, raised it a little, and even grabbed one of my wheel chocks. I had to intervene when he went to grab the 5lb hammer.
Adrian
2072 (789513)
Old 11-03-2015, 08:36 PM
Default 1872 and sweeper
Swept the leaves with the 1872 and Agri-Fab sweeper today. Little overkill, but it is the only tractor that hasn't been put away for the winter...
Had 37 full loads
Old 11-03-2015, 08:40 PM
Nice work Mr. Zippy.
Old 11-03-2015, 08:42 PM
What he said
Old 11-03-2015, 10:22 PM
jimbob200521's Avatar
Had 37 full loads
No such thing as overkill when it comes to Cubs! Great pics and thanks for sharing!
-Ryan
Old 11-04-2015, 08:32 AM
Had 37 full loads
Looks good Buddy. I wouldn't say it's overkill, Allen C uses a 982 to do the same thing.
