#81
Hey I have an Onan muffler from a JD 420 that you could fabricate to fit....Kinda looks like a Command muffler and the guys use them for repowers....
#82
If I do anything it will probably be something like this.
#83
I have this....
#84
Got a few more things done today. Made a set of spacers for the rear wheels out of a pair of old axles that came out of my 71. Cut the center out of the flange and drilled the bolt holes so that they slip over the studs on the later tractor. Had to space the wheels out just a bit because the JD wheels were just touching the brake pads. Then I got the grill shell and hood support cut and tacked together.
#85
Looking good Sam, other than the wrong shade of Yellowe on the rear wheels!
#86
I got a hood and grill off of a old 1050 gear drive that would look good on that rig.
#87
Looks nice, Sam!
#88
Got the grill/ hood support welded up today. The hood is mounted with some tabs that will be pop riveted once it is ready for paint. Welded a couple hinges to the support so far it works as it should. Got the seat support today. New seat is on order from Northern Tool, it will go on my 2182 and the seat that is on the 2182 will go on the UD.
#89
Ok I'm waiting on the headlight install!!
#90
