Old 05-03-2015, 10:33 PM
cub cadet 72 guy's Avatar
cub cadet 72 guy cub cadet 72 guy is offline
It's looking really nice
1961 Original
1962 original w/ fenders and creeper
102
72 w/ fenders and lights
124 w/ sleeve hitch
129 w/ lights
5 mower decks, 2 plow blades, 1snowblower
Old 10-12-2015, 12:33 PM
Gijazbo's Avatar
Gijazbo Gijazbo is offline
well its been a long time, i bought a 78 F-150 that takes alot of my time.
None the less, i cut the POs inserted metal off the plow undercarriage and re-welded it to the correct length. and got the blade cleaned up and painted. I didnt spend much time on this stuff as it will get destroyed the first time out.
Old 10-12-2015, 02:55 PM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
Your tractor looks great. It has been awhile since i have looked at this post. You have cone a long way with it.
I am broke, but I make it work!
Old 10-12-2015, 06:49 PM
twoton twoton is offline
Looking good. You got a thread on the F series somewhere?
Old 10-14-2015, 12:00 AM
Userj8670's Avatar
Default 126 problems with crank?
Been having some problems with the 126. Seems that when I turn right in second gear or above the pulley on the crank shifts back and grind on a bolt on the block? I can post pics if need be....anyone heard of this before?
Jim
Old 11-06-2015, 03:13 PM
Gijazbo's Avatar
So it has been a while. I have been busy with the 78' F-150, but i finished up the deck and plow.. minus the bar that moves it up and down (still need to bend that up)
Its not pretty, but its just going to get banged up anyways.
Did some booger welding to get the carriage back to specs.
As she sits
As for the gent lokking for the link to the 78' build... its low and slow, but here it is. http://www.ford-trucks.com/forums/14...4-rebuild.html
Old 11-06-2015, 03:34 PM
Gijazbo's Avatar
So, although it is pretty and nice now im still running into issues going full throttle and applying any load.
When i thro the speed lever all the way up to fast it bogs out. It will take 10-15 seconds to correct itself, or i can fiddle with the choke and it will return to normal RPM. I have no issue when i engage the mower deck, it only happens when i try to go fast or up a hill.
Im getting extremly frustrated and hopeing and praying that i dint mess something up on the rebuild.. becuse that thing is in there...
its hard to hear in the videos.. but
Old 11-06-2015, 03:35 PM
Gijazbo's Avatar
let me know if you cant click on the videos and i will put them youtube instead.
Old 11-06-2015, 03:51 PM
I didn't watch the video but from what you describe it sound like a fuel problem, something in the fuel system is plugged.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-06-2015, 04:55 PM
Good to see someone else w/an old Ford. I'm 79f3504x4 over there.
Tags
1250, 1450, 1650, rebuild
