#81
Lookin good, Todd!! I would think it should hold with a new bearing in there! Don't know if I would hang 500 lbs on the back, probably wouldn't do that to any bushing tractor anyways.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
#82
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#83
Looking good Todd.
#84
Axle tube repair should be fine. Good thing is that on an O you don't need to worry about an oil leak at the axle end.
#85
Got the engine nearly assembled. SG cleaned down to bare metal and primed. Holes in the hood welded up that don't belong......
Working on how to clean up the VR, slow process. What do you all do to te sides and back to get the rust off? Now I'm not referring to the cover ![]() Pictures tomorrow....
#86
Looks really nice Todd. Are you doing anything with the clutch? I'm rebuilding 2 O clutches and have sourced the end bearing, timken style thrust bearing, and thrust collar bushing from my local supplier. Did you get the front wheel bushings from cub cadet or local?
#87
Yes, the wheel bushings were from my local dealer. Couple pictures from the weekends work done. Don't think I'm liking the coil with the black top, think I'm going to start over and paint it all yeller, think that's the way it left the factory, correct? I know the bolts should be yeller also, but those are staying all natural. I like it better thata way.
#88
Looks great Todd.
#89
Looking good Todd,I would paint the coil all yeller.
Up to 534 and counting... I give up updating my profile! |
#90
Todd, my friend, you are doing such a killer job on this O.
