Old 05-07-2017, 10:52 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Todd,
I've been out of the loop for a bit with a busted computer, but happy to get back online and see you working on this one! Looking Great!! Jeffs parts are top notch! Glad to have him to help us out of binds... i'm sure his shaft will solve all your problems!
Jay
Proud owner of the following:
Old 05-14-2017, 09:03 PM
I'm back at it. I had Jeff make a new driveshaft out of 1144 stressproof and it turned out awesome. Thanks again Jeff for the quick turnaround time, your work is amazing. Here is what he used.https://www.mcmaster.com/#6628K344
He made the shaft as per my drawing so I had him make the 5/8 ends a little long so I could cut them for a good tight fit. That was a good thing because I had the hole for the 3/8 roll pin off a little and I had to trim a little off of the pump side.
The 3/8 carriage bolts for the front adapter went MIA and I couldn't find grade 5 ones anywhere except McMaster but I didn't want to wait and pay that much to have them shipped only needing 2 so I used regular grade 5 bolts. I had to shim out the adapter with washers as seen here. Do any of you see a problem doing this?
The back side fit great. I used all grade 8 on everything else but I only had grade 5 nylon lock nuts and also used blue thread locker on everything.
I also added an oil pressure gauge and had to move the hour meter.(I know, it looks a little ghetto) I'll make a nicer bracket when I have some spare time.
I tried to keep as much original paint on this tractor as I could so I wet sanded, buffed and polished that last few rainy weekends we had.
That's all I could do today. Maybe I'll get some time this week to do a little more.
Old 05-14-2017, 09:31 PM
flatpickerray's Avatar
flatpickerray flatpickerray is offline
Drive shaft looks real good, looks like it fit pretty well. The tractor looks good too, nice work.
Old 05-15-2017, 12:21 AM
Good work Todd.
Now clean that spot off the floor...
Old 05-15-2017, 06:34 AM
Wow, looking great Todd!
Old 05-15-2017, 07:58 AM
that thing is NICE.....i dont think will be a problem with motor side that way....
I have some 316 carriage bolts 3/8" x 1.5" i could send you?? i think 316 is about equivalent of grade 5....
Old 05-15-2017, 08:39 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Looking awesome Todd!
1- 1200 in pieces
1- 1864 in pieces
Old 05-15-2017, 10:05 PM
Thanks guys. Mj, thanks for the offer but I don't want to tear it apart again. McMaster has then so I guess I need to get a list of things needed around the shop and place an order.
Old 05-15-2017, 11:25 PM
jaynjeep's Avatar
Lookin good Todd!!
Get that thing all purdy for me and i'll trade you a yellow and white 986!
Jay
Old 05-16-2017, 10:53 AM
Inactive Member
Looking great Todd!
