Old 12-07-2015, 11:32 PM
I was pretty sure the muffler bearings were going bad and the kanewten valve had been making a lot of noise
Looks like you have eliminated those 2 possibility's
But seriously, What Happened?
Old 12-08-2015, 06:04 AM
MWShaw's Avatar
MWShaw MWShaw is offline
I had the rear tins off of it, because I was moving the rear three point to the 1772.
As I started to put it back together I noticed it had a oil spot under it. Soooooooo......... It appears the crankcase vent was not functioning properly and the internal pressure pushed the crank seal out, the one behind the stator.
Parts are on order. I have to re-glue a couple of the flywheel magnets.
Then it will some quality time with the pressure washer and go back into service with a dozer blade, snow cab and chains. Until I get the H42 set -up on the 1772 (or find a good 450 for it).
Once the 1772 is ready to move snow, the 782 will be sold. Sadly I cannot make enough room to keep more than one tractor.
Old 12-08-2015, 07:09 AM
budscub's Avatar
budscub budscub is offline
Default No problem with crankcase pressure
I wish my 782 would push that seal out. Mine has a positive crankcase vent custom installed before I got it. Works 2 ways, one the big opening allows any pressure out, and 2 if the pistons don't move with the crankshaft it generates no pressure. But I knew this when I bought it. I already have a vanguard to install, just a matter of it making it to the top of the ole list.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 12-08-2015, 09:00 AM
MWShaw
Great pictures, Looks like you have it under control.
Keep us posted on your progress.
Old 12-08-2015, 10:02 AM
Gotta love this 60 degree+ weather in December. Sprayed some paint outside over the weekend on the GT3100 deck. I'm still learning... and got a couple runs on the vertical sections. I'm thinking I need to get a gun just for spraying paint and use my existing one for primer.
Hooked up the redneck parts hanger and sprayed some primer. There are over 20 small parts on the 3k decks.
Old 12-09-2015, 12:12 AM
Ah, hangers, you'll get that on them big jobs Todd
As per our phone conversation, those HF $25 guns work good for this type of "work"
Looks good from here, go with it
Old 12-13-2015, 10:51 AM
bruce s's Avatar
bruce s bruce s is offline
Default Did a little cab work
I've been doing some mockup on a cab I bought about 8 years ago . I got my 782 painted that summer so I didn't want to scratch it up getting the cab put on it.
I acquired this 1204 in a deal so I thought I would get the cab fabricated up and mounted on it, then put it on the 782 .
My lovely wife is making the front vinyl part of the cab . I know it isn't any thing that will hold heat I will still have to dress for the occasion , but it will make things a lot more pleasant.
Old 12-13-2015, 12:42 PM
jubilee's Avatar
jubilee jubilee is offline
Default Worked on and with the 1782
The 1782 got new fuel lines, filters, fuel shutoffs and grommets this past week plus brake adjustment and was buffed out and waxed. It runs and looks much better! Then, we had fun shredding all those oak leaves that keep falling on the yard.
___________________
Jim
782 w/Command 18,
1862 not running;
IH 42 inch blade; off brand cart
Old 12-14-2015, 11:29 AM
Great pics, guys!
Old 12-18-2015, 10:01 PM
1811woody's Avatar
Today I pulled the shields off the Kohler m18 in the 1811 and replaced the starter and torqued the head bolts. tomorrow I will clean up all the old grassy oily buildup that sits inside and under those heat shields. It took a lot more time to get the shields off then to do the rest of the work. What a pita to get the bolts out on the bottom of the motor!
