Old 12-18-2015, 11:05 PM
1811woody's Avatar
Great pictures ACecil
The new sweeper looks like it is doing an excellent job
x2 your new sweeper looks great behind your 982!
Old 12-19-2015, 12:45 AM
Originally Posted by 1811woody View Post
Today I pulled the shields off the Kohler m18 in the 1811 and replaced the starter and torqued the head bolts. tomorrow I will clean up all the old grassy oily buildup that sits inside and under those heat shields. It took a lot more time to get the shields off then to do the rest of the work. What a pita to get the bolts out on the bottom of the motor!
I find it easier and faster to pull the engine... Your mileage may differ.
Old 12-19-2015, 11:49 AM
1811woody's Avatar
I debated about that thank you for the tip.
Old 12-20-2015, 03:04 PM
Tony h's Avatar
Tony h Tony h is offline
Winter temperatures showed up this weekend so I spent a bit of time reading the Cub sites. Searching for Steering in particular. After getting a handful of knowledge I went out side (just for a minute to look at something). Next thing I know I had the Drag link and Tie Rod down. They were put on wrong by P.O.
Then I checked and tightened the Axle Bolt/Nut... very loose. Put the rods back up correctly, they were put on in such a way that they were binding on each other. Looked at the tires; they were not even close to pointing straight at the same time. I centered the steering wheel and made the proper tie rod adjustments. For a guy that was staying in the warmth today, I got the Steering much tighter. The alignment makes the tractor steer much easier and the turning radius is much improved. No need to look at Super Steering it. I'm happy with what I got now. A good day All while still wearing my slippers. I WAS just running out for a minute : )
If I can't fix it , it must not be broken
Old 12-20-2015, 06:11 PM
twoton twoton is offline
Tony, did you say "sites"? You mean there's more than one?
Glad to hear you got your steering worked out.
Old 12-20-2015, 08:09 PM
Tony h's Avatar
oh no, did I say that out loud?
ihcubcadet.com is one I surf to help and be helped. I hope I'm not banished from this site.
Old 12-20-2015, 10:05 PM
yep thats it you're done.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 12-21-2015, 12:37 PM
Thank you!
Old 12-21-2015, 12:39 PM
Got the 982 out for some run time yesterday evening.
Old 12-22-2015, 10:50 AM
That is a gooooood looking Tractor ACecil
