#9081
100 was on support duty for some chainsaw work in dad's yard. Yes that is a school bus seat, 8hp motor, oversize rears, and driveshaft out of Lord only knows what. Hey, this things been on work detail for the last 20 years!
#9082
I have been working at my cab on the 982 that I have modified. Didn't like the slanted front on the Sims cabs - so its now vertical like they should be in my opinion. iphone transfer 1382bb.jpg
Mike Ontario, Canada IH built 982, IH built 782, IH built 782 parts tractor, 100 w/fenders & lights, #4 trailer, 42" front blade, IH 2B tiller, 12" Brinly plow, Brinly cultivator, IH push mower, Sims cab, IH snowthrower, 450 blower. Now everyone wants a Cub! ![]() Beware of the Wife
#9083
Nice 100, John!
The 982 cab is looking good, Mike!
#9084
While I had the fender pan off the 1641 to replace the fuel lines and fix the deck stop I decided to do something to the rusty pitted footrest. I have a small sandblaster that I went over them with the sprayed the with Rusty Metal Primer. I found some Rustoleum Marigold That looked close so I painted the bottom and sides with it. After it dried I taped off the footrest area and sprayed two coats of Rustoleum Truck Bed Coating on it. After the last coat I removed the tape and the liner had wicked back under the tape and it looked like crap. I just decided to spray the whole top side with the bed coating. It's hanging in the laundry/mud room drying now. I didn't actually do all this today. Painting in the winter without a heated shop is a PITA. I bring the part and paint in the house, let it get warm, take it to the garage and paint it then bring it back in to dry. The next step is to hunker down for the complaints about the paint smell. Picture of the footrest before the coating shows the pitted top. Picture of them hanging from the cabinets in the laundry room drying. I probably won't put them on till tomorrow.
Cannon |
#9085
Had to troubleshoot my non-charging issue with my 122. Ended up re-wiring most of the tractor while I had it apart.
![]() Yes, all the wires are the same color, which isn't perfectly ideal, but I had the wiring on hand already so stuck to this as a free upgrade. Jury is still out on if my charging issue is fixed... not been able to go back out to check on it since re-wiring it. Maybe tonight... My luck, it'll be the voltage regulator. ![]()
#9086
Cannon |
#9087
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
#9088
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
#9089
Pretty close...
Used my iPhone's panorama feature to get the photo while sitting about 1' away from the tractor.
#9090
thats the nascar edition, only mows left.
