#901
Over the weekend I took them all out of hibernation for a ride and pictures. All but the two with plows, 125 and 1450, have been sitting since November. Only one dead battery on the 126. The rest started right up.
No pictures, but I plowed Sunday and Tuesday with the 125. I tried on Monday too, but there was too much, had to use the truck. A snowblower would have been nice. We had about 18-20 inches. I’m all out of places to push it, and they are saying we may get another storm over the weekend.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
#902
Today I decided to tackle the frozen choke and throttle cables. Took the throttle control off the inside of the tower (two round head machine screws with nuts and lock washers inside) and found that the cable jacket unscrews from the throttle lever assembly. (which means a replacement would need to be the exact same diameter and thread pitch) so I pulled the inner cable out, clamped one end in the vice and pulled some 320 sandpaper to clean it up. Then flushed the inside with wd40, and pb blaster, then poured graphite powder in the end and pumped some engine assembly lube. Also coated the inner cable itself after fixing any bends. For the choke, I had to straighten the zee bend at the carb with plyers to yank it out. I wasnt about to try and get the backer nut off the choke way inside the tower. Did the same procedure, and remade the zee bend after the inner cable was back in.
They both work again great but not sure how long this kind of fix will last tho...
Model 100 Dec 2020 - Running condition, has snow plow! Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one Model 100 Feb 2019 apart for total frame-off / sandblast etc resto Model 70 Sep 2020 needs total resto and an engine, or for parts Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts. two spare hydro rears "in for a penny, in for a pound!" |
#903
I will also add that when I have cables with no coating on them I always put shrink tube on them to seal them shut so moisture stays out and the lube stays in.
#904
Thanks Tim, yeah its outside for now no shed for it. I will get a small tarp tho... and the heat shrink idea may be just the ticket at least for the parts thats not underneath the hood..
#905
Added wheel weights to my 782
#906
Plowed a path to my shooting backstop so I could play with a couple of my favorite 1911s
#907
I plowed the snow on my driveway with my cc169, never had to use even 1/2 the throttle.
I will be installing a set of 2in wheel spacers , this will give me 4 additional inches of wheel track in the rear. Also I discovered that my reverse is as fast as my forward. Not good. Have to get under the frame and see what is going on with the linkage. |
#908
More better to remove tunnel cover, yes?
#909
Well if you say so, I have only had my Cub for 6 months and Im still learning. If I had to guess, Im going faster in reverse than I do in forward and Im going plenty fast in forward so I know something is amiss.
But speaking of the tunnel cover, I noticed that the bolts that hold it on were somewhat loose, I looked at the screws (somewhat fine thread, closest thing I could find was 12-24. But it just seemed like the wrong screw, so I made the bold move to tap those holes with 1/4-20 and Im glad I did. The cover holds down like it was meant to and 1/4-20 is a standard ubiquitous bolt. |
#910
Added a second rear weight, had a tube put into one rear tire and then pushed snow
