Old 04-01-2016, 08:55 PM
Patched a hole and added a couple braces to the Haban today. We may get some lawn mowing weather some day and wanted to be ready for it...
Old 04-01-2016, 09:53 PM
Dirty Steve's Avatar
Ah, braces on the 374. Very nice.
Old 04-02-2016, 12:09 PM
Nice work, Todd!
Old 04-03-2016, 01:13 AM
Thanks guys... Sam suggested braces last year when I got it, but they didn't get done till now.
Old 04-03-2016, 10:56 PM
aagitch's Avatar
aagitch aagitch is offline
Those braces look good.
Adrian
2072 (789513)
Old 04-03-2016, 10:57 PM
aagitch's Avatar
Went to a plow day Friday and Saturday. Took a pic of my friend on the 1872.
Adrian
2072 (789513)
Old 04-04-2016, 01:22 AM
Great action shot Adrian.
Can't wait to smell some fresh dirt being turned.
Old 04-04-2016, 01:33 AM
cjet69's Avatar
cjet69 cjet69 is offline
After changing out the bad coil yesterday. I pulled the 44A deck off, put the blade on , and pushed a little dirt/gravel with the 1450.
CC 1450, 44A deck, #2 tiller, 42" plow/blade
CC 124
CC 1220
#2 Cart
Old 04-04-2016, 10:46 AM
bbrown8's Avatar
bbrown8 bbrown8 is offline
Default 680 Hydro
This is more of a "What did I do with my Cub This Weekend" post.
The 680 was in need of some major TLC on the motor and mower deck.
For the engine department I Seafoamed the engine which seemed to help with a sticking exhaust valve. I've been running the MMO since I got it just in the fuel. I did an oil change after the Seafoam and added some MMO to the engine oil as well. I only run Non-Ethanol fuel, but the previous owner didn't. I did a carb rebuild on the K301. The float needle had been sticking causing it to flood the carb and stink up the garage. While at it I replaced all the fuel lines and added an In-Line fuel shut-off (I was using needle nose vice grips previously to choke of the fuel so I didn't flood the engine - petcock is hard to get to on these engines for "everyday" use.
I also replaced the rubber engine mounts. Those babies were SHOT! Between the seafoam, carb rebuild and new mounts the old girl runs like a top now. I also fiddled with all the cables - cleaned the choke cable as it was sticking. While reinstalling the carb the K301 wanted to rev to the moon, but I followed the static governor settings and reined the motor back in. Gave me an excuse to use the Laser RPM meter I have
On the deck I power washed it. Repainted the bottom, its not great job, but it will keep the rust away until I can get the deck sand blasted. I also replaced the tensioner pivot bolt that holds the idler to the deck. The original one was rust welded to the pivot. It was not easy getting it all separated and cleaned up. The new bolt has a Zerk fitting so it can be greased to prevent this. I had to zap a hole in the top cover of the deck so I could service it without having to remove the top cover.
I also made a "Striping Kit" for the deck. I got my hands on some heavy duty rubber and fastened it to the back of the deck. I believe this is similar in concept to how Ferris does their kits on their decks.
Now she's ready to mow snow (Thanks Ohio!):
Thanks for reading - its a long post, but I pulled some long hours tinkering on the old girl.
-Buster
1984 CCC 680 Hydro. Attachments: 44C Mower and QA36A Snow Thrower.
Old 04-04-2016, 01:36 PM
Great pics, guys!
