Old 02-12-2021, 07:11 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by paulcc169 View Post
Well if you say so, I have only had my Cub for 6 months and Im still learning. If I had to guess, Im going faster in reverse than I do in forward and Im going plenty fast in forward so I know something is amiss.
There are adjustments for that. Plenty of help on this forum, but best to start a new thread if you need it.
Old 02-13-2021, 04:05 PM
CubbyRI CubbyRI is offline
Default Replaced shifter knob
Today, my cub has a new shift knob. Every little part helps!
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 02-13-2021, 08:52 PM
sawdustdad's Avatar
But speaking of the tunnel cover, I noticed that the bolts that hold it on were somewhat loose, I looked at the screws (somewhat fine thread, closest thing I could find was 12-24. But it just seemed like the wrong screw, so I made the bold move to tap those holes with 1/4-20 and Im glad I did. The cover holds down like it was meant to and 1/4-20 is a standard ubiquitous bolt.
Well, excellent choice to tap those holes. I've done that, like 10 times. LOL. Makes it so easy. I use 1/4-20 Phillips head screws. A long screwdriver reaches those pesky front screws easily.
As to the speed issue, remove the tunnel cover and adjust the length of the rod that runs from the speed control column to the hydro's cam plate. Might want to check the hydro's trunnion while you are at it. A common wear point that often needs attention and repair to get consistent hydro speed control and it's possible something has been jury-rigged there as well. The tech library has lots of stuff on trunnion repairs.
Good luck!
Old 02-14-2021, 11:41 AM
paulcc169's Avatar
paulcc169 paulcc169 is offline
Many thanks!.. I actually enjoy tinkering on this tractor.. by the way, I finished installing the 2in wheel spacers for a total of 4in of added track.
Old 02-14-2021, 03:17 PM
WesternCannonball's Avatar
WesternCannonball WesternCannonball is offline
Woke up yesterday to 5 inches of snow (and still falling) that I didn't believe was actually coming, so I didn't have the plow on.
Shoveled a couple driveways by hand, then spent the twilight hours wrestling the plow onto the 122. Got it on, then found out the battery was dead. The dumdum who ran it last left the key in the on position after shutting off the gas.
So, this morning, with the snow STILL falling (up to about 8 inches now, maybe more) fired it up, grabbed my girlfriend for ballast (don't own any weights) and plowed our 500 foot driveway, as well as two neighbors.
Got done, into the field for some fun driving, and she promptly threw a tire. The wheel was turning, the tire was not.
So, now, she's tarped up until the snow stops falling and/or I can dig the spare wheels and tires out of the storage area.
Anyone know what size the rears are for a 122? Mine have been on since before my dad bought her almost 30 years ago, before I was born, and the numbers are all but illegible. All I can make out is "Goodyear"
It all started with a little 122......
Old 02-14-2021, 05:08 PM
Depends on what size rims are on the tractor;.
Picture???
LOL thats funny. Cool GF to ride with you. My ol lady rode on my lap the other day on the 100. (Not easy to make that work but it was fun!) I was told that skinny ags with lots of weight are best for plowing. But its really about weight mostly I think. I use all inner tubes in everything to avoid flats, add some strength, and better for liquid filling.
For tires on my 123 I bought 23X8.50-12 ag tires. I have the wider rear wheels. The skinny rears on my 100 model use 6-12 tires.
These are the 123's tires i bought:
www.amazon.com/gp/product/B01M7MKV7S
Old 02-14-2021, 05:36 PM
Yeah, riding double on a single seat is not easy. I have a 2x12 plank in place of a seat just for carrying a passenger, so we both rode sidesaddle, she operated the lift lever, leaving me free to shift, throttle, and steer.
Mine has turf tires, not ag, but they are definitely not as wide as the ones you said you put on the 123. The 6-12's look pretty close. It's a place to start, anyhow! I may not replace it if it didn't take too much damage, maybe
a tube. Thank you for the size marks!
Old 02-17-2021, 01:12 PM
three4rd three4rd is offline
Let's see...what did I do today on the Cub? Tried to get it to start...most unsuccessfully. Same for yesterday.
Old 02-18-2021, 04:13 PM
ICOM 756 ICOM 756 is offline
picked up 2/17/2021 took carb off its full of the magic green stuff hahhahh.
fuel in the top hole fired up so its a plus.
