#9631
Got the 2372 (1872) ready for it's winter nap. Cleaned up the Haban, removed the front mower angles and put grease between them and the shell to hold out moisture, and hopefully keep rust out.
Oiled up the underside with waist oil, and finally installed the new blades. Picked up this NOS hour meter awhile back, and finally installed it. Figuring the "new" engine needed a new hour meter. Blew all the dusk and crap out from around the engine, and put it away for the year.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#9632
Nice work Todd!! Always great to pull it out in the spring ready to go!
![]() I like the new hour meter! Now you can say you got a NEW tractor next year!! ![]()
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#9633
I wouldn't say it's a "new" tractor, it's better than a new one.
#9634
Maintenance is the key, Todd. Nice touch with the new hour meter. And hardened blades too!
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
#9635
Got some tires filled w/fluid today.
w/the fluid (W/S washer) and the weights I added + 2 link chains, I'm at 185# per wheel. 3 weights per wheel. 2 are modified dumbbell pieces, drilled and notched for valve stem clearance and 1 Cub weight on the outside. This should make the 882 push some serious snow. |
#9636
Nice work Mr. Z keepin' it clean...
sound like a lot of poundage for the 882,are you a person that is lean ?
Up to 534 and counting... I give up updating my profile! |
#9637
Thanks Master of LEW.
Clean is good.
#9638
I got my dad's 1440 all cleaned up for winter hibernation, it gets used to mow around the buildings and despite my best efforts it sits outside all summer and was covered in black stuff. Hopefully I can get a coat of wax on it tomorrow before it gets put away.
#9639
You do good work there Tim.
#9640
