#9701
All those tractors with hydraulic lift and your gonna put a plow on one without?
#9702
Looking good cubcadet! Nice model 123 too!!! I bet you have a nice IH spring assist for it! I was on the hunt for the IH spring assist myself!
Diz jr. , Aww, 'nuthing to it! Good work on replacing that crankshaft!! Have a good day gang!!!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#9703
Thanks John, I like this 123, has lights too!
#9704
Thanks guys
![]() cubcadet Nice work |
#9705
#9706
Why not replace the head gasket now, instead of "soon"?
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#9707
Diz, what happened to the original camshaft?
Nice job Nick. Did y'all get any snow yet?
#9708
Thanks guys, yes I will be replacing it soon, just have to order it, will do it once it goes back in the tractor and at least runs good with no other oil leaks, my seal should be in in a couple days from Napa, no snow yet Todd.
#9709
since im waiting on parts for the turbo build i decide to do a few other things that have been bugging me. for one the sagging coolant hose rubbing on the valve cover has been bothering me so i took care of that with a few things i had laying around. the valve cover had these 3 mounts for who knows what so i utilized one of them. the stainless #10x24 screws i had fit perfect in the pre-drilled holes. just dripped a tap in there to give me some threads. next, i bent and twisted a piece of steel for a bracket, then used a PVC clamp to hold the coolant hose to the bracket. worked out good.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
#9710
next up was the rear hydro ports that were held on with a zip tie. i ditched the zip tie for a hydraulic hose clamp. made up a bracket and bolted it to one of the support bars for the backhoe. makes popping the quick connects on off a breeze and i looks much better too.
