Old 03-19-2010, 06:22 AM
Magnum Magnum is offline
On the way home yesterday I stopped by the case dealer and picked up a belt for my tiller..... Different guy than before so of course he said I needed a different size belt. I picked up one thats 143.8 inches accoding to the thats supposed to be the one I need, and it was the only size they had in stock, I figure I'd give it a try, might get to that tomorrow morning.
Last night I took off the snow blade, pulled off the cover from the rear to change out and put Hytran in it and started working on getting the tiller mounted. After getting the cover off and cleaning the old gasket while the fluid drained I tried to change the filter and realized I didn't have a filter wrench, let someone borrow it. So I took measurements on some other parts I needed. Then I cleaned up, went to Home Depot and picked up some all thread and steel so I can make a belt tensioner for the muler drive and get rid of the spring, Had to get 1" bolts to bolt the gear box on to the rear, and picked up a Clevis, and some quick links to use from my lift pin to the chains on the tiller since I do not have the adjuster T and rod and my pin has a horizontal hole in it.
I'm working all day today then as soon as I get home I have to go to the other job so I won't get to work on it again until Saturday
Old 03-20-2010, 08:06 PM
Changed the oil in the 100 today. Had to get a pic while it was in the sunshine!
Old 03-20-2010, 09:07 PM
Today I tilled... then noticed my tire was flat when I was done, you can tell in the video by how far the tiller is leaning.
Old 03-20-2010, 09:13 PM
aagitch's Avatar
aagitch aagitch is offline
I've been sitting around waiting for my wire harness to be built for the diesel so I decided to experiment with a stainless steel pipe that the PO gave me. I haven't decided to keep it on or put the stock muffler back on. I like it but my wife shook her head at it.
Old 03-20-2010, 10:16 PM
Thanks for the great vids, Magnum!
Your 982D looks great, Adrian!
Old 03-21-2010, 02:41 PM
toyman's Avatar
toyman toyman is offline
Got them cleaned, oil changed and greased in the nice weather.
Original Member #54
Old 03-21-2010, 03:27 PM
Amigatec's Avatar
Amigatec Amigatec is offline
What's that Green thing doing there?? :biggrin2.gif::biggrin2.gif:
Pat Benner Haskell OK
Old 03-21-2010, 05:52 PM
ihnick's Avatar
ihnick ihnick is offline
nice clean tractors there
Nick.
Old 03-21-2010, 07:14 PM
IHinIN IHinIN is offline
Finished up my sleeve hitch adapter. I just need to paint it. I'll post some pics later. Now to decide what attachments I want to build/buy.
Old 03-21-2010, 08:09 PM
squatch squatch is offline
I've been tearing the super apart to get at many items that need fixed or upgraded in the next couple of weeks. Today I got the grinder and cup brush after all 4 rusty wheels and cleaned and primed them. I little paint and then I can mount and load the new tires!
