Greg Rozar AKA- CubDieselFan
Old 08-25-2018, 06:36 PM
Jbo_c Jbo_c is offline
Default 122 only running sort of great
Picked up a new to me(obviously) 122 this week and it starts and runs great. - sort of.
Using it to pull a little swisher rough cut mower today which should be cake for it. But whenever it’s under any stress (like going up a hill)in second gear, it lugs, acts like it’s going to die- and sometimes does. In first gear it does OK. Third gear is out of the question. On flat land, it does fine in all the gears.
When it dies, I have to wait a minute to crank it back up. Makes me think it’s a Fuel supply issue.
I’ve adjusted the carburetor and even swapped it with a known good one off my 126 and it still acts the same.
Going to replace the fuel filter tomorrow, but what else should I be looking at if that’s not a magic bullet?
Thanks.
Jbo
Old 08-25-2018, 07:09 PM
Hate to ask but does it have enough gas in the tank?
Pull choke and see if it picks up any when issue occurs, if so it’s a fuel supply issue. Maybe tank or sediment bowl screen clogged?
How is the governor adjustment? Top rpm 3600?
Old 08-25-2018, 07:18 PM
Excellent question. Plenty of gas. Choke has zero effect.
Jbo
Old 08-25-2018, 07:23 PM
I’m thinking if the filter is clogged, the choke might not matter much ‘cause it’s not getting fuel anyway.
Thanks.
Jbo
Old 08-25-2018, 07:27 PM
Sounds like it.
Roland Bedell
Buy: Made in the USA
Old 08-25-2018, 07:40 PM
Thanks.
Jbo
It came from the factory with a sediment bowl. That might need cleaning.
Old 08-25-2018, 08:01 PM
Somebody’s removed the sediment bowl along the way. Just a little pancake style filter now.
Jbo
Old 08-25-2018, 08:08 PM
Jbo
I highly suggest replacing it with a sediment bowl. Various vendors here have them plus they are available at NAPA and other auto or farm stores.
The thread coming out of the tank is 1/8" NPT
Jeff
Old 08-25-2018, 08:09 PM
DieselDoctor's Avatar
Clogged filter? Shut-off valve open all the way? Remove the line from the carb and allow fuel to flow into a container. Make sure you good flow.
Old 08-25-2018, 08:14 PM
I have good flow from the filter. (Added a shutoff so fuel briefly went everywhere.
Pardon my ignorance, Jeff, but what’s the advantage of a sediment bowl over or in addition to a fuel filter. Seems to me a fuel filter would be a reasonable replacement for a sediment bowl. ?
Thanks for all the feedback.
Jbo
