1604 with no headlights
I just got this machine, and I'm going through it trying to button up any loose ends on it. I can't get any of the lights on the machine to work, I'm guessing that the first on position of the key is how the lights are turned on. I've checked with a test light and I'm not getting any power to any of the lights, so that rules out bulbs. I tried googling and searching here, but the 1604s seem to be a model that isn't commonly talked about. I would appreciate any help, maybe my ignition is bad, or there is a fuse i missed.
There should be 2 run positions on the key switch. I think after you start it turn the switch to the left one click and that should be the lights on position.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Should be a fuse in the dash for the lights
Im embarrassed to say that it was just a fuse. It looked fine when I looked at it, but I switched it out anyways and everything is working perfect.
Thank you for your help. |
Those glass fuses will fool you like that. Got me before.
no need to be embarrassed, I don't think there's any of us who've not "been there, done that."
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
Yep, I can see the read out on my multi-meter better than those tiny elements. And these miniscule little blade fuses they're using now, oh boy.
1450SGT 1641 528 SWE Snowblower, |
