Old 11-29-2009, 07:38 PM
transformer transformer is offline
Default anyone seen this before???
This is a pic of my 70s steering housing...Dont think I can revive this one..I was in the process of taking it off the tractor to rebuild and found this..Pics not great but at some point this thing came apart on the inside and shoved the bearing out through the casting on the housing....you can see the bearing pushing out of the hole in the casting....I honestly think I can fix this one but dont think its worth the trouble...Let me know what you think....
Old 11-29-2009, 08:11 PM
Mouse's Avatar
Mouse Mouse is offline
Never seen that before, does it still work?
Mouse
1969 125 Cub Cadet
1962 Cub Cadet Orginal
2009 Cub Cadet LTX 1046 VT
1963 Cub Cadet 100
1966 Cub Cadet 122
Old 11-29-2009, 09:44 PM
yep it still worked ...had a lot of slop in it... thats the way it was when we got it.....
Old 11-29-2009, 11:01 PM
It looks like it's starting to spider web around the hole, and it appears that there is a crack started around the circumference about where the top of the plug is. Might be a difficult fix.
Old 11-29-2009, 11:21 PM
Yep it will be a tough one....I cant believe it was not locked up after I got it out and looked at it....I'll try to tear it down and clean it up tomorrow and see what the shaft looks like inside and how many bearings are left....lol...Ran out of day light .....story of my life...lol....
Old 11-30-2009, 06:21 AM
Inactive Member
I have seen posts worst. Water can get down there from sitting outside and then freeze. From what I can see (the eyes are not as good as they use to be)
you can either patch this one up, or replace it with a new or used one.
Old 11-30-2009, 11:26 AM
I didnt think about water getting down there but that would sure do it..I have another sector out of a 147 the only difference I can see is that that tube is shorter in my 70....Does anyone know if the tubes are pressed in the cam follower housing.?If so I might take the guts out the 70's change the tubes and put the 70s guts in it...Has anyone done this? thanks for the input....Randy
Old 11-30-2009, 11:43 AM
Don't know about your tractor but in the quietlines it is really common for the tube to be loose and floating....and you need to expand the tube for a press fit when rebuilding.
Old 11-30-2009, 11:51 AM
klejeune's Avatar
klejeune klejeune is offline
Unless you're worried about the 70 being exact, I'd just throw the 147 column in there and call it good.
I like pie
Old 11-30-2009, 02:06 PM
Leon renaud Leon renaud is offline
the 70 I got a short time ago to be my first true restoration has the steering box broken in 2 pieces. The bottom and half of one side are broken off in one pieces on the diagonal !I'll try to get some pics once the rain stops here.This tractor is in bad shape something other guys might use as parts but for me I want it for the learning curve it will provide.I can't believe I'm saying this but I'll buy better projects later!
