Old 12-22-2023, 06:54 AM
CoreyF CoreyF is offline
Default Need carburetor info for SV541-3212 Cadet
I'm a new member and this is my first post. I own the Cub Cadet
Model :13AVA1CS056, SV541-3212.
I'm having no luck finding the COMPLETE repair kit for the carburetor, part #KH-20-853-95-S. I found this carb kit fine online, but I only need the rebuild kit with O ring, needle valve, jet, ...etc. so I can rebuild my existing carb. I think using the original carb might be best instead of trying some other brand.
Also, can someone provide me a link to a video/pics, or all detailed steps to adjust the carb air/fuel mixture once I replace this carb with a new one? Are there two adjusting screws or just one? I'm pretty sure I've determined I need to rebuild orf replace the carburetor but want to try adjusting the carb CORRECTLY. I'm sure I've ruled out any other issues/replaced other parts that could be causing an engine surging problem.
Old 12-22-2023, 07:38 AM
ironman's Avatar
ironman ironman is offline
You can read all about your carb in the Fuel System section of the Service Manual for your Kohler Courage here.....
https://resources.kohler.com/power/k..._690_01_EN.pdf
Old 12-22-2023, 11:55 AM
Thanks Ironman, that link helped a lot however, the manual mentions that I should adjust the low idle screw then adjust the low idle fuel adjustment needle. The fuel needle is attached to the float inside the bowl. I don't see anywhere in this manual that shows a fuel adjustment needle in addition to the float needle. Am I understanding what's being said in this manual?
Also, should I worry about replacing welch plugs if they are clean already?
