Can't find new blades for my 1450
Hi,
I have a Cub Cadet 1450 Mower and I'm having trouble finding new blades. The mower is 44". I'd like to order new mulching blades. The original blades are part # 759-3402-0637. The are 15" in length and have a 3/4" hole. Can anyone help recommend some new mulching blades? I'd prefer to not order the same ones I have now and would like to try something new. However, all of the ones I'm finding online are either too long or different hole size. Thanks. |
If you don't mind grinding 1/8" off each end, Stens has this mulching blade...
https://www.stens.com/355-089-mulching-blade https://www.stens.com/web-assets/med...082.1684323631 |
Are those blade holes 5/8" as on the chart reads or 3/4"?
( chart is awful small to read even after blown up) |
Heck even CC/MTD sells them still.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
The OP specified "mulching" blades.
Thanks all for the help.
I see the blade you linked (355-089) has a center hole of 5/8" instead of 3/4", so not sure that would work. I do think I might be able to use a slightly larger blade though. There is about a 1/4" clearance from the edge of the blade to the mower deck. 20230519_172026.jpg |
The "Gator" brand of mulching blades were good. Some how they sold out or were bought out by Oregon Products (https://www.oregonproducts.com/en/products/lawn-and-garden/c/lg-p).
I am not sure that Oregon Products kept the production on the IH Cub Cadet Mower Deck Blades. If you can find them, the Gator Blades for the 44" deck was 90-957.
Most times the horizontal is no concern, as it is easily compensated for by height adjustment. That said, a blade center hole can be drilled out but one has to use a carbide drill or end mill, as a high speed drill is just about as hard as the blade material, causing much heat and as much smoke as a heap big native american poe-wow. |
