Old 08-27-2014, 11:10 AM
ford4150's Avatar
ford4150 ford4150 is offline
Default Engine leveling
Removed my Kohler engine today and found a single washer between the oil sump and frame on the front two mount bolts. Is there is a procedure for engine leveling?
Old 08-27-2014, 11:37 AM
kostendorf's Avatar
Was the oil pan pad machined because of damage from bolt coming loose? All the pads should measure the same. I think they are 1.060, I don't remember for sure but this may be the reason for the washer.
Old 08-27-2014, 01:06 PM
IHinIN IHinIN is offline
Previous owner may have been trying to adjust for a bent frame. I had a 126 that had a stack of 3-4 washers under the back of the oil pan to make up for the bow in the frame from someones hack job trying to put a K321 in it.
Old 08-27-2014, 01:09 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
or maybe someone that knew what they were doing worked on it and knows that the majority of cub cadet's don't have real good alignment from day 1.
