Not sure if I am the right place or not. I have 1989 1050 that I just acquired and want to change the oil. I cannot find the drain screw. Can anyone help?
Hello and Welcome! yes you have found the right place OCC !! the drain plug will be on the oil pan,you may have to clean some crud off to find it,but thats where it is!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
Tex, you got a keeper there. There were very few of the 1050's made. As Hank Jr. said, it is on the bottom of the pan. You need to down load the Kohler Mag manual for the engine in your machine. If you have any problems let us know. Good luck!
How about some pics of your 1050! |
Thanks, will get some pics posted shortly. It is in pretty good shape, runs well, clean body all panels intact. I paid $450 for it and bought it from the original owner. It does smoke on startup, will investigate more. Where can I find the manual for the motor, it is the Magnum 10. Thanks
One other quick question, how often does the tranny oil need to be changed and what fluid does it use. It looks clean, it is a manual transmission.
Still owe you guys pics, but I am in the process of repainting. Did not plan to do it, but had to pull motor to rebuild the clutch. Working on painting the frame tonight. Trying to find some motor mounts that are no longer available.
Are you looking for the rubber mounts or the steel brackets ? I have a set of solid mounts that I bought and never used from zach kerber.
I just now realized this thread was from 2012. LOL Never mind
