Old 10-06-2017, 09:28 AM
David K David K is offline
Default CC 122 starter turns don't crank engine
turn the key the stat gen turns but the engine don't turn over.
I charged the battery but it don't seem to make a difference.
any one know what to check or do next?
Thanks in advance
David
Old 10-06-2017, 10:05 AM
Terry C's Avatar
Terry C Terry C is offline
Tighten the belt? Or are saying the SG is trying to turn but wont? Or is it spinning the belt.
Will the engine turn by hand?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-06-2017, 02:48 PM
Well if the starter/gen is turning and the engine is not, either the belt is missing, loose, or the Starter/gen pulley has come loose and is slipping on the shaft of the starter/gen.
Old 10-06-2017, 05:19 PM
Or the basket pulley is broke, lost the key, or stripped out.
Old 10-07-2017, 06:36 PM
The belt is on. Not sure bout basket pulley never fooled with that. Guess I'll have to learn about it.
I Thank all of you for the help for help.
David
Old 10-19-2017, 11:17 PM
Well I tightened this and adjusted that, kicked it a few times and threatened it once or twice, called it a few names then turned the key and walla it started.
Old 10-20-2017, 08:47 AM
Amazing!
I'm sure that the threats are what did the trick
