1641 snow blower
I have a Qa 42 snow blower mounted on my 1641 and was wondering if anyone knows what size belt it takes from the pto to the gear box? Thanks in advance
Well... a QA42 won't fit on a 1641, but a QA42A will attach.... BUT, it wasn't made to go on that tractor. Your on your own if you want to make it work. You will need a different pulley on the blower for sure unless that was last on an '82 style tractor. Even with a different pulley, I don't know if it would work on a cyclops.
I made a QA36A work on my 1864, but it took A LOT of jacking around. Make this piece, make that piece, grind this, weld that, start over...
It can be done, and it did work, but... lots of Monkey F****** around. Looking back, I would've done things a little differently, but still would have went that route cuz I didn't have $500-600.00 to shell out for a model 451!
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
Ended up scoring a good deal on a 1250 and a 1450 parts tractor so it looks like the 1641 will have a blade and the blower is going on my 1250 after I set the hydraulic lift up on it... seems like less headaches than making the blower work on the 1641 but thanks for the info
