has anyone actually gone thru with a homemade spring assist
I honestly looked through every single page of the ih cc forum and came up empty. Has anyone successfully made a nf spring assist and do you have pics.
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
What he did was take a small chunk of steel in the shape of an L, drilled it for a bolt and bolted it into the frame of the 107 using an existing threaded hole. Then he drilled a hole through the other end of the bracket for an eye hook. Attached a spring to that. Then on the end where the implement lift rod attaches to the CW-36, he took a small piece of bar stock and drilled one hole large enough for the hook in the spring, and another hole large enough to go over the implement lift rod. Reassemble, and adjust the spring tension as desired. Works good. He may have drilled another cotter pin hole on the implement rod. I can't remember. Would work with a snow plow too. Doesn't help if you're wanting rear implement lift though. Hope this at least gives you some ideas. |
Brinley SA is easy to make. A factory 1 would be harder.
I've seen the brinley. Would that still help on the front end?, I would assume it would since everything is tied together.
I have made several of them in the past couple of years.
Unfortunately, the "closest to factory" springs that I have found are 1.5" in diameter and the factory springs are 1.25" so the ones that I have made will ONLY fit on gear drive Narrow Frame tractors (they rub the side of the rear end housing on hydros).
