Old 04-17-2014, 01:34 PM
possompatterson possompatterson is offline
Default 12hp motor
I'm kind of upset. My motor turned over perfect the other day. I got new points and condenser on it, and comes to the top and won't move. Is motor blown all ready or does any one know what I should do? Valves maybe..??
Tried to sell my body for cab fair i ended up walking home
Old 04-17-2014, 02:14 PM
More details. What do you mean "comes to the top and won't move"?
Old 04-17-2014, 02:16 PM
Inactive Member
What is the model of the Cub you are working on...???
Old 04-17-2014, 02:17 PM
It won't make a full rotation. The piston doesn't seem like it wants to go to the top.
Old 04-17-2014, 02:20 PM
It's a 126. I'm getting frustrated with it. I cant afford to do much with it, cause I'm laid off, but gotta mow my yard. I spent money I didn't really have for this problem to arise.
Old 04-17-2014, 02:37 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Can you turn the S/G pulley full rotation by hand?
More than once?
Old 04-17-2014, 02:50 PM
If you pull the spark plug out can you turn it over by hand?
Old 04-17-2014, 02:58 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I suspect you have the ignition timing advance to far or your compression release isn't functioning. I'd check the timing since you messed with it
Old 04-17-2014, 03:13 PM
Yep that why I asked if he can turn it over by hand with the plug pulled. If not something else is wrong inside. Do you agree?
Old 04-17-2014, 04:10 PM
So, now its turning over, even fired a few times, but gas is pouring out of the carb. It's gonna sit till I can afford to fix it. I guess the grass is gonna grow.
