1641 steering box
One of the few good things about this covid pandemic, is, I get to catch up on some long overdue maintenance. I have about 150 degrees of free play in the steering. So it’s time to tear it apart. I tried to upload a video but it keeps giving me an error. I send pics along the way😁
Sounds like some issue(s) in your Lower Steering Unit.
Got the assembly out and cleaned up. Here are some pics. Not too bad but the worm gear has some chunks missing. Should I file those down or should I replace the shaft? I’m getting a new cam follower as it is worn too. The ball cages seem worn. Should I replace those or just add a couple of extra balls like I’ve seen some guys do? Besides those items, everything else, like the bushings seem fine.
Thanks! Do you have any thoughts in regards to the worm gear or adding more balls?
No, Sorry, Never had one apart.
Looking at that I'd be looking for a new or good used worm gear.
I've not heard of adding more balls?
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
Gotcha. I’ll start the search for a good used one...While searching for steering rebuilds on this site, I came across one topic where one guy removed the cage and added two more balls to tighten up the steering. Maybe I read it wrong. Ha
Cannon |
The worm gear looks fine where the cam follower rides. Just make sure there aren't any large burs sticking out and file them off.
Rusty 149 project with: QA42 snow thrower 38" deck Barn fresh 1811 with: 44c mowing deck QA42A snow thrower 42" snow blade |
