No lights on the 782d
They were working great night before. Tonight nothing, just wondering if there is a common problem? The dash light is out too.
thanks |
Are there no lights at all? Does the oil warning light come on when you turn the key to the on position with the engine NOT running? If so you could have a disconnected wire or bad headlight switch. If you do not have the oil warning light mentioned above, then you may be missing 12V due to a bad connection or bad key switch.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
the oil light does work but all others do not
Did you check your fuses?
i think they are gone they are not in dash tower
No fuses that I know of in the 782D, BUT there is an circuit breaker on the RH side of the tractor near the voltage regulator. However if you have the low oil pressure light you have power. The same power that feeds this oil light also feeds the headlights through the headlight switch. I would ohm out the headlight switch or CAREFULLY quickly jump it.
Sorry, I didn't catch it was a 782D. Looking at the wiring diagram, I am thinking a bad wiring connection.
it was the switch thanks to all
Glad to hear you got it figured out!
