Go Back   Only Cub Cadets > Resources > What is it worth ?
Old 11-09-2016, 02:45 PM
CSXengr's Avatar
CSXengr CSXengr is offline
Default What is it
Found this in a local junk yard. First what is it? found this number on the side 149 630 100 000078 0059. Not sure if that is the model number or not Next what is it worth?
CSXengr
_______________________________
124 w hydro lift, 124 creeper gear, 125,126,128, 129,147 electric lift, 149 w/tiller, 1200, 1450 dual 1650 w/tiller control hydro, #2 Cart, Haban sickle mower, Gannon, 17 cubic inch cart.
Old 11-09-2016, 02:47 PM
CSXengr's Avatar
Default Another shot
Another picture.
CSXengr
Old 11-09-2016, 03:48 PM
Inactive Member
It is a 1989 model: 1211.
Old 11-09-2016, 04:12 PM
CSXengr's Avatar
Thanks. It is in ruff shape, so if I could get it cheap it might be worth messing with just need to make a deal. Thanks again. I will keep you posted.
Gary
CSXengr
Old 11-09-2016, 07:14 PM
A 1210
Up to 530 and counting...
Old 11-09-2016, 07:23 PM
A 1210
What he said, If it's cheap I'd go for it. To bad it's not a 1211, a hydro tractor with manual lift is a waste. I can sell you all the parts to add hydraulic lift.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-09-2016, 07:35 PM
Inactive Member
According to the Cub Cadet Parts Look Up site........it's a 1211.
Old 11-09-2016, 07:57 PM
Hard to argue with your findings but a 1211 has hydraulic lift and a 1210 has manual, I wonder if the frame or tag could have possibly been switched.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-09-2016, 08:00 PM
I agree..... BUT, the 1211 had hydro lift while the 1210 was manual. It's possible that he read the number wrong as the only difference is "2" or "3".
Looks like a good parts machine. Probably take quite a bit to get it going again. I wouldn't give more than about $75. I suppose if the tires hold air, it may be worth a bit more, but not much. Looks like it's been there for quite some time.
Old 11-09-2016, 08:08 PM
Inactive Member
Done some research into the archives. The 1210/1211 are identical except....1210 has Manual lift....1211 has Hydraulic Lift.
Now given the picture and the model tag data posted, seems something does not jive.
