Aluminum grill housing
When I was at the pulls in Springfield last winter I could have swore I saw someone selling an aluminum grill housing for a narrow frame. Am I crazy or has someone else seen one? If they're out there where can I buy one? It looked just like the original cast nose. I need to loose some weight to get to 950 and it's easier to put the tractor on a diet than myself! Also how well does the Nichols aluminum hood match the original steel? Close enough to pass as OEM?
midwest super cub has them in fiberglass which is even lighter, i just checked and they also sell it in aluminum and it weighs 4lbs
I'd love to run a glass nose but it needs to look like a factory grill to stay in the class I'm running.
actually the fiberglass is about 6lbs heavier but it looks more like the original than the aluminum.
The nose I'm looking for is cast aluminum not the sheet metal. So it looks like a factory casting once painted. Uses stock grill and head light panel, just lighter.
D & M small engines sell the cast aluminum front grill. It's a 1X2 style.
Thank you sir, that is the one! I could not for the life of me remember the name. But as soon as I saw D&M I recognized the name, thank you.
You're welcome! There is a cast aluminum front Axel too, but I am not 100% sure who sells them. |
D&m also sells the axles.
1872 - 60"haban 54" power angle haban blade '63 Original - restoration project 582 -tiller 147 - leaf duty with bagger. 1811 - Ditch mower 800 - have it just cuz its a 800 |
Grille
A lighter version for the 70/100 would be the fiberglass piece from Amstutz pulling parts in Indiana. The aluminum one is lighter but still heavy, the plus is you could push on the aluminum as opposed to the lighter fiberglass.
