Old 08-20-2015, 05:24 PM
Lil Indian Puller 128 Lil Indian Puller 128 is offline
Default Putting a spread frame puller together in NW PA
HI all,
this is my first post but i'm putting together a spread frame puller.My Tractor is a cub 1204 the engine is a kohler 18hp magnum opposed twin and i have a rear end out of a cub 1000 my questions are what clutch and drivers should i run and would the midwest super cub IH1066 fender work on this chassis andwhat kind of exhaust to set up
Old 08-24-2015, 07:23 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
your in kind of a bad spot. no one makes parts for the opposed twins so you'll need to either make something work or make the part yourself
Old 08-26-2015, 07:06 AM
cadet104 cadet104 is offline
cub made a 1806 for a short time which was a 18 magnum with the aluminum housing 3 speed also a model 1535 was the same thing. There should be parts some where. I have a Midwest set up in my 104 just the basic fiber disc and there drive plates with the stock driver. Haven't had any slip yet
Old 08-26-2015, 07:07 AM
Oh and I'm using the red spring
Old 08-27-2015, 09:19 PM
dvogtvpe's Avatar
clutch parts would work but its not like the Mag 18 has any real performance parts available. I don't think you can even buy a billet clutch hub adaptor , steel flywheel , decent rods and I don't even recall seeing any cams offered. I'm sure Lacota ,Vogel or Greg Hackman can grind them
