Using Case IH brand paint 101 questions
I hope for some help in some question for a noob like me when it comes to painting. Never painted a tractor before. This will be for my 1650 restoration.
Im going to use Case Ih paint with an air gun. I bought some white 935. The directions say to use 8 parts paint to 1 part thinner. Which seems a little off to me. But I would like to use hardner too. Then Im reading some threads about a 8:4:1 ratio, and no word about thinner but using a reducer. I hate to ask such silly questions but with so many threads suggesting different things its hard to figure out what Im gonna need to use and what ratio. Any help would be grateful. Thank you, Nate
-IH Cub Cadet 1650. -44A Deck. -CC Snow Blade. -Brinly 10" Plow. |
Thinner is for lacquer, reducer is for enamel. That is 8 parts paint,4 parts reducer and 1 part hardener. And by the way I also use Case IH paint and I have had good luck with it on a few decks. Hope this helps.
lacquer paint hasnt been made for 10 years. except for what's in cheap rattle cans.
your paint store should have a mixing cup with the chart on it. I use the 2 to 1 and add 1/4 hardener.
Doug Original / IH 70 / IH 149 / IH 1650 / IH 582 / CCC 1772 West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
Thank you very much! This will help me out a lot!
Thanks again. You OCC guys are the best! -Nate
the best paint, its what i used to paint my 100R.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10: |
