126 puller project
hey guys, im new tot he forum and idk if u do build threads here but they do on the 2 stroke forum im on too. so i have a build here i have been working on, it is a 1970 cub cadet 126 it had the k301a in it that i am building slowly. but i am putting a 25hp kawasaki liquid cooled vtwin in it. the paint and everything isnt really good at all cuz im building it on a budget and sense i got the motor for free from my shop in school. im going to pant the shop logo on my hood and school logo on my fenders. but here are pictures of progress so far.
Your off to a great start! Thanks for the pics! |
Hope you are going to beef up the rear end, you are going to need it
Donny |
well some wat. i talked to a puller with a highly moddified 25 twin (50hp/73 ft lbs) and wins a lot of events, he said stock 25 you dont need to touch the diff but im getting 1100lb clutch springs and a different drive shaft, he said the pin hole in the rear, that will stay and the shaft will twist. end up like one of those old twisted iron fences haha.
but i neeed some sites to buy the stuff from could u guys help me with that or if you know something i dont. always taking suggestions
you still have alot of variables but ill try this first...clutch needs upgraded including driveshaft and what the clutch is such as a 3 puck clutch, cant promise you a kevlar disk would hold or not, stock axles have to go they might last awhile but if you get it to hook up good there toast, 6 pin driver is a must, not sure about what gears you would need.
Again to help more we need to know weight class, tire size, RPM and what type tire bar or professional? to give you a better idea. Just a heads up most places that motor is not considered a "stock motor" because its liquid cooled here are some parts suppliers for pulling parts hope that helps http://zkbrmachine.com/ http://www.midwestsupercub.net/ http://www.vogelmanufacturing.com/store/index.php http://www.nicholsperformance.net/ http://www.amstutzpullingparts.com/ |
Looking good! Appreciate the pics.
im going to keep the motor all stock but ill use it in what ever class i have to. ill prolly run in like a 1200 class? maybe 1150. i getting the tires today ill put a pic up. they are ag tires but have a lot more lugs than most i see. rpm would be mostly likely right around 4000. its a 26 inch tire i also have 23's on it now. so the parts ii want to upgrade are:
clutch drive shaft axles 6 pin driver (i dont know were that is or wat it does) possibly gears. let me know if i need anything else!!! |
a 6 pin driver is going to be a little hard to do since the motor is liquid cooled it would normally bolt on your flywheel but judging from the picture its hidden by the radiator. It is basically a heavier driver with more pins to better distribute the force of the motor to 6 pins instead of your stock 3 pins. Look at some of the websites for a 6 pin driver and you will have a better idea of what I am talking about
