Old 04-24-2012, 06:32 PM
john hall's Avatar
Default 682 blown engine--options
Had a 682 brought in with what appears to be a blown engine--no compression on one side and oil leaking on the ground. Originally this tractor had a series 2 that blew with 200 hours-- a new short block was installed. The tractor had a new deck installed several years ago but has only had a few hours put on it. Priced a new engine at $4k, definitely not an option. Are new replacement M18 engines available and if so, how creative does one have to be to re-do the wiring? Whats the machine worth now, $350-500?
Old 04-24-2012, 08:07 PM
John
If you’re looking at re-powering it I don't think you will find an M18 or a K series that would be cost effective. My guess is your best bet would be a Vanguard or a CH Kohler. Even at that you’re looking at $1500 + the cost of extras like a muffler. Other options would be finding a used beat up 2160,2165 or a 2185 Cub with a good engine for a donor, rebuild what you have or part the tractor out. I'm sure others will have some ideas.
Old 04-24-2012, 08:48 PM
Vince_o Vince_o is offline
I'd go with what Sam said. We have some deere guys here that repower their 400's with Vanguards. Commands are good too. Check your crank size and check the wiring between the two and don't send 12V to the coils.
Old 04-24-2012, 11:04 PM
Or get a good used engine.
Old 04-24-2012, 11:37 PM
john hall's Avatar
Thanks for the replies. Seems like any new engine will cost more than this thing is worth. After blowing 2 of them the owner is probably not willing to consider another one of these, even if it were rebuilt. If he offers it to me at a decent price I may consider a re-power option. I'll let you know how it turns out.
Old 04-25-2012, 07:19 AM
John
You say hes blown 2 of these motors. What showing up as the failure? If he blew up 2 of them, not wore them out, the customer has got to be doing something wrong.
Old 04-25-2012, 07:41 AM
John
I have a used Kohler CH22 that came out of a 2284. It had some minor issues that have been fixed. PM me if you think it's something that work for you.The pic is it after I test ran it on my bench.
Old 04-25-2012, 07:49 AM
Inactive Member
YUP....you have a customer problem as opposed to a Kohler problem. Chances are, that once this is fixed up, another engine will die.
Old 04-25-2012, 08:03 AM
What Vince & Roland said!
Old 04-25-2012, 10:26 PM
john hall's Avatar
Finding another engine locally is going to be pretty hard, Cadets became oddballs here about 20 years ago. Looks like this one threw a rod through the block--oil is leaking out but can't see where with all the sheet metal on it. I can see the valves working when I look through the plug hole. It also let out a bunch of smoke when it happened. Engine is shaking bad as well, won't be running it any more. I can't fault the owner, he didn't own it when the first engine blew and has put almost 1200 hours on this one and has never been into the engine. If he offers it to me for a song, I may grab it. Of course I would rather have an 18XX series (to match my 2072).
