129 hydraulic lift isssue
I have a 129 with a hydro, lift. Today while plowing snow I noticed that it is barely lifting the blade (Its worked great up until now)
Is there a a fluid res. that is just for that ram ? Thanks Tim |
No, The fluid is Hy-Tran from the sump on the hydro.
The level may be low. Check for leaks. Has the fluid and filter been changed recently? Does the unit move backwards and forwards as it should? |
Thanks for the reply
Forward and reverse seemed ok and the lift was fine when I started and even when the lift stopped working forward and reverse worked alright |
It might have sheared a roll pin on the rock shaft. Mine did that once and the blade would barely lift off of the ground.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
129, hydraulic lift???? Does it have an after market unit on it. 129 is manual lift. Someone may have put a 149 hydro in it to get hydraulic lift.
All it would take is a ported pump and the rest of the kit from a 1450 or a 1650.
I assumed that is what has been done. |
Hydraulic lift was an option for the 129, 109 back in the day.
109 and 129. No hydraulic lift were available from factory. Sold hundreds of them new at our old dealership. Also if you look at parts book for 109 and 129 there is no ported pump available like for a 149
I also owned a 129 with one it an was original to the tractor.
Cub Cadet website parts lookup for 129 shows it too.
