Old 07-02-2012, 07:20 PM
ClickClickBoom ClickClickBoom is offline
Default k341 timing
Having a heck of a time getting this motor timed. I attempted to do the static method and couldn't get it quite right, so i bought a timing light hoping it would be easier to adjust while running. These points are infuriating.
Got the light hooked up, and it will sometimes flash, but sometimes not at all. The timing us close enough to where it will start and run, but the more you throttle up the more it surges. When it surges it blows black smoke like it's running rich.
Any ideas why the light isn't working? Some other ignition problem?
Old 07-02-2012, 07:54 PM
I also tried grounding the light on the battery, frame ground, and various areas on the motor. No change.
Tried moving the clamp various areas on the plug wire, and turned it arid every which way no change
Old 07-02-2012, 07:58 PM
Another possible symptom. Sometimes when i turn the key the motor turns over fine. Sometimes the starter engages, but it's like it's trying to turn over a high compression v8. If you hold the key it will turn over very slowly, and the turn over at full speed. I put a new starter on suspecting that was the issue, and while it now turns over faster, the problem remains
Old 07-02-2012, 08:56 PM
brentwd's Avatar
brentwd brentwd is offline
I had the same problem on a k321. It had the same probs as yours and I did the very same steps and it turned out to be the point and condenser. Put the new ones in and didn't even have to time it. 20 thou. and it was good. Hope this helps.
Old 07-02-2012, 09:13 PM
Vince_o Vince_o is offline
just one tooth off will do this problem. Did you put the balance gears back in? I never do.
Old 07-02-2012, 09:29 PM
Not a rebuild, i just pulled the motor to do the mounts. It seemed to have a bit of a miss/ stubble, so i decided to static time it while it was out.
Maybe I'll try new points/ condenser. Had to give up for the night before i pushed it into the creek behind the garage.
Old 07-02-2012, 09:40 PM
cmatthew's Avatar
cmatthew cmatthew is offline
since you have the motor out, you should also clean and possibly rebuild the carb while your at it.
CC 123
402c Sickle Bar, 48" Mower Deck
QA42A Snow Thrower, 42'' Push Blade
IH Back Blade and Rake
Brinly Seeder/Aerator
Brinly Lawn Rake
Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc
Old 07-02-2012, 11:07 PM
Motor is back in, but it's no problem to pull the carb
Is there a guide somewhere, our are instructions in the service manual? Where is the best place to get a rebuild kit?
Old 07-03-2012, 07:30 AM
Mat has a real nice write up on building carbs. Im sure its here some where and someone will post a lik=nk to it. Preaty easy carb to build, bigest thing is make sure your emulsion tube is clean and the float is set right.
Old 07-03-2012, 09:55 AM
cmatthew's Avatar
go to your car parts store and pick up a gallon of parts cleaner/soaker. works great. then blow it out with a compressor. rebuild kits can be gotten at our sponsors. hold the float under water and check for leaks.
CC 123
Brinly Lawn Rake
