Greg Rozar AKA- CubDieselFan
Old 09-18-2009, 11:27 AM
BajaGTO's Avatar
BajaGTO BajaGTO is offline
Default Noob with a 1450
Got a couple of questions....
Picked up a 1450 last night. Traded it for my old non running craftsman lt4000 and $100. I think I got a fair deal. Hey, at least this one runs.
1. How can I tell what year tractor it is?
2. Only the right side of the deck lifts up. It looks like a pin has slipped through a hole on the left side under the frame. Does it just need a washer and cotter pin?
3. What model snow thrower do I need for this tractor?
4. How do I adjust that cam thing on the right side by my feet? What is it's purpose? It doesn't seem to move.
Thanks,
Ted
Old 09-18-2009, 12:33 PM
WALTER's Avatar
WALTER WALTER is offline
Smile
bajaGTO(Tom)
First, welcome to only Cub Cadets.
Try this kink if you do not have the owners manual.(Operators Manual for the QuiteLine Series.... Q/L Series ) It is on page 3 in the Technical Library-Tractors.
Hope this will help.
Walter
Old 09-18-2009, 04:08 PM
ajgross ajgross is offline
Inactive Member
1. If you post the serial number, we can tell you what year it is.
2. Your pin is broken and missing. The missing pin is what we call a "Spirol" pin. The technical term is "Coil Spring Pin". You just need to get a new one and install it. And no, a roll pin probably won't hold up.
3. QA36A or QA42A. The 36 is s36" wide. The 42 is 42" wide.
4. The cam thing is to control your implement height. You adjust it to basically control your deck height. The lift will hit the cam and not allow it to drop any farther. You just need to lossen the black plastic bolt, adjust the cam, and then retighten. Just make sure you don't have any pressure on it.
AJ
Old 09-18-2009, 04:40 PM
BajaGTO's Avatar
AJ
Thanks. The only issue I see is that the arm that hits that cam doesn't seem to move when the deck moves.
And the SN# is 2050660U582653
Old 09-18-2009, 05:16 PM
Your 1450 was built in April, of 1976.
Old 09-18-2009, 06:52 PM
Hey BajaGTO,
Is this what your talking about?
Like ajgross said loosen the black knob part and the cam will rotate to adjust. It dosnt move with the lift, it stays put and the lift arm runs into it. Get your height where you want it and rotate the cam around till it hits and tighten it up. Hope this helps:biggrin2.gif:
Old 09-19-2009, 12:11 PM
BajaGTO's Avatar
Hey BajaGTO,
That;s exactly what I am talking about. But...that lift arm on the right doesn't seem to be attached to anything.
Old 09-19-2009, 12:29 PM
nathans nathans is offline
If you have a 1450 with a hydro lift then there will be no handle. It is for attaching a lift rod to blower of snow plow.
Old 09-20-2009, 12:04 PM
Inactive Member
If the arm isn't moving, then you probably have a broken pin on it. Just look and see if the pin that holds it on is there or not.
Old 09-22-2009, 10:53 AM
BajaGTO's Avatar
I think this may be directly related to the fact that the left side of the deck doesn't go up and down. Am I on the right track?
