Greg Rozar AKA- CubDieselFan
Old 09-21-2009, 08:20 PM
IHinIN IHinIN is offline
Default What oil for transaxle?
I drained the oil from the transaxle on my 100 and it had gear oil in it but the original owners manual says to use 30wt motor oil. Which should I use? I would think the gear oil would be better.
Old 09-21-2009, 08:50 PM
Use what IH & Cub Cadet recommends......SAE30WT or HyTran
Roland Bedell
Buy: Made in the USA
Old 09-22-2009, 12:01 AM
dieselsnowmobile's Avatar
dieselsnowmobile dieselsnowmobile is offline
I just changed mine this weekend for the first time, I put Rotella SAE 30 in it. Rotella does not have the API for gas engines that have extra chemicals in it. Book says 7 pt, but I put almost 8 pts in mine, course I tipped the tractor to the side to fill it a little higher.
CC 104
Old 09-22-2009, 05:08 AM
Alright, thanks guys.
Old 09-22-2009, 01:21 PM
ajgross ajgross is offline
Inactive Member
Hey IH. Welcome to the forum and it's always good to see another hoosier here!
AJ
Old 09-22-2009, 03:18 PM
Merk Merk is offline
I replace the oil with Hy-Tran Ultra anytime I change oil in the rear end oil. Hy-Tran Ultra has an oil encapsuplating properities in the oil. All Cub rear endsare not a sealed unit....meaning moisture can and will get in them. This is a good example of moisture in the rear end:
I haven't put a load on this rear end yet.....hope it is ok.
This is the rear end in my "Project Uncle Dick 70"
http://www.onlycubcadets.net/forum/s...ead.php?t=1270
Old 09-22-2009, 08:05 PM
AJ
Thanks AJ
The oil in mine looked fine but I didn't know if it would be safe to put gear oil back in it or not. It just seems to me that gear oil would be better since that's what most manual transmissions and axles call for.
Old 09-22-2009, 08:38 PM
HyTran is what the International Harvester farm tractors have in there rear ends. If it holds up in the big tractors it should work great in our Cub Cadets.
It's your tractor....do with it what you want to.
Old 09-23-2009, 04:57 AM
Good point Merk.
Old 09-23-2009, 08:02 AM
RPalmer's Avatar
RPalmer RPalmer is offline
Works pretty good in floor jacks too. :biggrin2.gif:
