Old 12-11-2018, 10:27 AM
Woodtrucker Woodtrucker is offline
Default Carb Choices for K241
I have been trying to start up the Cub Cadet 100. Throttle shaft on carb seems really loose and wobbly so for the sake of winter and getting my machine up and running asap, I think I'm going to shoot for a replacement carburetor. Would either of these be a recommended buy? I am capable of modifying the throttle linkage to fit either model by way of machining if necessary. Just need my new cub up and running asap so I can push snow. Already had 15" of snow and it's not even mid december yet!
https://www.ebay.com/itm/Kohler-K241-K301-M10-12-Cast-Iron-10-12-HP-Carburetor-NEW-Replaces-CARTER-26/191136693833?epid=2087438874&hash=item2c80a27e49:g :CVYAAOxy3zNSjoMn:rk:5f:0
https://www.amazon.com/gp/product/B0...k_ql_qh_dp_hza
Cub Cadet 100 #66758
Old 12-11-2018, 10:40 AM
sorner's Avatar
sorner sorner is offline
https://isavetractors.com/kohler-car...0-m12-engines/
You want to make sure to get one with the two different choke shafts. Because in my experience they always come with one installed that is backwards and wont work with the choke cable in these tractors. So you swap out the choke shaft and it works. Be careful to not lose the little ball in the choke shaft hole. When you pull out the choke shaft it will pop out because it has a spring behind it.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 12-11-2018, 12:03 PM
Mudrig150 Mudrig150 is offline
Depending on how loose it is you might be able to just buy the throttle shaft. My brothers JD had the throttle so worn it was oval shaped. Replaced the throttle shaft and took 75% of play out of it.
Old 12-11-2018, 01:37 PM
finsruskw finsruskw is online now
Install the bushing
