Painting over paint
I have a 1250 I want to paint but don't want to sandblast the tractor. Paint is in decent shape, few scratches here and there, and faded. Can I just paint over existing paint as long as I degrease and clean it really well? Or do I have to primer the whole tractor first?
Clean it up very good. Scuff it up and sand it smooth and paint over it. As long as the base paint isn't flaking or has rust on it should be fine. I did this on my 1200 frame.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
Scuff and go. I've done it on parts I can't get it the sandblast cabinet.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
What do I scuff it with? A Scotch Brite pad? If so like what grit? |
scuffing it will not remove imperfections from the original paint and they will be magnified when you put fresh paint over top of it, id recommend wetsanding the parts with 400 or 500 grit wetsand paper.
