NF to WF bracket problems
I picked up a 42 inch snow blade complete with a NF mount. I want to remove the NF mount and replace it with a Wide frame mount for my 1811. When I got it, I thought I could pull both pins and it would slide side to side enough so I could remove the NF mount, and put the wide frame mount back on the same way. But it will not move enough either way. I thought that long rod that the clips go in would move, but it is welded so it will not slide out. There must be a way to change these, any ideas would be helpful. Thanks.
The Sub Frames for the Dozer Blades are different. If you want a WF Sub Frame, then you will have to acquire one. You can do an internet search, put an Ad in the Wanted Section in the Classifieds, or contact Sponsors Houtz or Patton located at the top of the page.
If you have a Cutting Torch, Welder, and some Flat Stock Steel, you can always fabricate something to make it fit.
You have to spread the mount apart enough to slip it over the pin on one side.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
I have a WF subframe that I am willing to sell. Let me know if you are interested.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
Thank you for the info, will try to pry it over enough to get it out. I have a wide frame mount already but thanks for the offer.
