Greg Rozar AKA- CubDieselFan
Old 01-19-2024, 12:05 PM
sorner's Avatar
sorner sorner is offline
I'm still planning on selling this but I just stumbled across something today while looking in the manual for something for a potential buyer. I noticed the "421" kit for the supers includes longer lift brackets, that are 1 3/4" longer than the standard ones, so THAT's why it's not going all the way to the ground.
1912 with Kohler M18 engine repower, CI rear, 50C deck, 364 snow blower
IH Cub Original with deck
#2 cart
GREEN 314 with integral sleeve hitch, H2 and independent brake upgrade from a 317, and front hydraulic blade, 48" deck
Old 01-19-2024, 12:49 PM
Farmall450's Avatar
They had to compensate for those big tires one way or another!
Old 01-19-2024, 06:29 PM
Can you make one using the shorter bracket as a template adding 1 3/4"?
Up to 530 and counting...
Old 01-19-2024, 06:34 PM
sorner's Avatar
Probably could. I have some straps from a QA snow blower that I could use to make those.
#2 cart
Old 01-19-2024, 06:35 PM
AHHHH you will be blowin" in snow, I mean no time.
Tags
364
