Got A New NEW Tool
look what fell off the truck and landed in my garage today
it has enough butt to run a DA and a sandblast cabinet at the same time the air water separator will be here tomorrow. it 5hp 80gal 15.5 @ 90psi |
Thats sweet!!!
Thats a piece of junk just ship it here to get it out of your way Congrats!!
1782 smoker!!, 169 and parts 128 And a bunch of stuff that fits on the back of them LOL |
OK , just as soon as I get a car painted. I'll put it on the first thing smokin .
who should I sent the payment book to? |
Very nice, you'll have fun with it!
I have a 7hp 80 gal compressor. You'll love it, especially if you've been doing your stuff with a portable compressor. While it will run both an orbital sander and a blasting cabinet at the same time, you won't be happy with the performance of either. Remember, those specs printed on the tank and the printed material are very optimistic. It will run either one of those things individually quite well, though.
I recommend mounting a water filter near the tank (mine is actually mounted together with the regulator valve right on the tank outlet) and another water filter as near as possible to the outlet where you will hook up your tool. The filter at the tank will keep a little water out of the lines when the compressor starts up, but once the compressor starts to heat up the warm air holds the moisture until it cools in the lines, then the water condenses out and gets into the lines (and into your tools). The second water trap catches that and protects your tools and paint job. Once I get my shop completely plumbed for air, I'll probably eliminate the trap and pressure control valve at the tank and just put a ball-cock valve. I'll put a water trap and pressure control at each station and add an auto-lubrication filter where I use pneumatic tools as well. All that stuff is available at Harbor Freight at good prices. Who knows about quality, though. I figure if it works to my satisfaction, it's ok.
Tony Stafford, VA 1650, 682... |
I got a sharpe water separator. and 2 other off brands. it is recommended they are put as far away from the tank as possible. it give the air time to cool so the water comes out and into the bowl. I have a pressure regulator at the tank to slow the air down. 90psi. then a water separator every 25' so the new sharpe filter is over 50' away from the tank.
I dont want the sharpe to be working hard to get the water out. so the other 2 do most of the work and the sharpe gets the rest of it. and the sharpe has a regulator on it to set the pressure for a paint gun . also my paint gun has a pressure regulator (to fine tune it) and a small water separator (just in case) I paint cars , so I dont want any water at all in the air. I ran the compressor till it was hot and checked the moisture level comming from the tank. its about 65% and at the gun it was 3% . I also will soon have an electric purge valve on the bottom of the tank. it pops open every 20min or so to let water out of the tank. it has a 1/4" line that runs out the wall. my other compressor is a upright 60gal 5hp that got very hot and made lots of water. it would keep up with all my tools but would never shut off untill I was done using the tool. the moisture level on it at the tool was 18% when hot. it'll be in the forsale section soon , if there is a place to post it. (havent looked yet) |
Nice addition to the family 4SPEED, Yeah my cousin just got the same thing and him and I have been restoring his Jeep and it has worked flawless.
102-P Narrow tires no creeper--42inch deck and IH blade. 102-D Wide tires,creeper,headlights--42inch deck and CW36 snow thrower. 1997-2086 Super with 3 point hitch and all the bells and whistles. 1961-PTE-"O", needs lots of work. 2072-Repowered with a ch18, Woods tractor. 149 with my Dad. 44" deck and QA36A. #9-70 with weights and sleeve hitch. #10-149 with a 38inch deck. 2015 Kubota BX 2670. |
this is about an hour after the trunk lid was cleared
http://www.youtube.com/watch?v=_oP2Gc6JAoo the next day. 2000 grit sanded , buffed & polished looks like black chrome |
Wow! (Must be 10 characters) so Wow again! Nice paint job!
Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
