Reverse on my 1882
Everything has been going well on the tractor until yesterday. Reverse was always a litte slow for me BUT it worked. Now yesterday it stopped working to the point where I had to get off and push it back. Lucky I was almost done. I did check the hydro level with the dip stick. It looks to be at the right level and looks clean. So should I maybe pull the seat pan / fenders off and pull the valves out to just give them a cleaning with something? see if they are free of and debris? I really need it up and cutting by the weekend.
thoughts folks? |
Pull the valves out and switch them, if reverse works and forward doesn't then you have a bad valve.
Take a look at the trunnion springs. Plenty of threads here about this subject.
http://www.onlycubcadets.net/forum/s...ighlight=Tough
Here is a link to what happened to me with my springs. I put some new plates in also. Mine were quite worn.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Thanks for the answers and things to try all. I'm going to tear into it tonight. I have to say I did sit on a new machine last night at lowes.. BOY I was tempted but I KNOW they aren't the same type of machine. I was almost lured by a cumfy seat and beer holder. HA HA.
I'll post what I see tonight. I'm still learning what all the parts on these machines do. I can rebuild my car inside and out. But learning these things is another story. |
I'd take a broken 1882 any day over the best that Lowes has for sale.
As a matter of fact I have done exactly that with an 1882 that had a hole in the engine.
Here are a few threads pertaining to tractors like you have.
http://www.onlycubcadets.net/forum/s...ad.php?t=33244
Yeah that's really nice. I'd love to tear into it.. repaint it. I do think that if I get reverse fine again (which I'm sure I can) I'll order a replacement grill for it. The tabs where it mounts to the frame broke and I plastic welded them best I could but the one cracked again and it's just not the same. So I'll order a new one along with a new grill insert. My side panels are scratched from bushes and the one has a small crack in it but it's not bad.
I'd love to restore it some but I can't take it offline that long since I do need to use it at least weekly to cut. |
I think I'll run to the cub dealer at lunch and see if I can pickup more hydro oil and a filter and change it while I'm into it. Now would be the time I think. Can't hurt to have fresh even though it looks really clean.
Here is a good deal for oil and a rear cover gasket.
http://www.onlycubcadets.net/forum/s...ad.php?t=44690
