CH 22 Kehlin Carb clean and rebuild
I am off work this coming week. I have had the carb kit and gaskets for a while now. So I surgically removed the carb this AM before it got too hot. I had my cordless vacuum trying to keep all the dirt out of the intake. Went pretty smooth. Covered all openings with duct tape. Kind of sketchy tearing down my only mower but lawns are not growing and more brown than green right now. We are horribly dry for the end of June.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
This is only the second carb I have ever been into so all suggestions are welcome. I first blew the crud off with air. Then I cleaned the outside with carb cleaner. Then split it in two. There is some sort of brown sticky goop on the original game style gasket between the two half. This I did not anticipate. Is this some type of sealant I need to reapply?
More photos. And then into the Pinesol. Hope this works. Oh, why the attention to this carb? It would not idle down. It would hunt and surge terrible when not running wide open. It mows the lawn very well. I am sure if I were a knowledgeable mechanic I would say something like the middle and idle circuits are compromised. What ever that means.... So wish me luck. Gonna need it.
After 24 hours in the Pinesol, I washed the carb up and wiped it down. Replaced all the o-rings. Put a small wire into all the jet wholes. Blew threw all the passages with carb cleaner. Put it together and took it apart four times in an OCD frenzy. Then finally achieved peace with my work. New top and bottom gaskets. New air and pre-cleaner. New fuel filter and gas line up to the carb(Cleaned the tank, tank valves and all new line forward to the filter last summer). Runs pretty damn smooth. Very proud of myself! I would upload a video if I could figure out how. Anyways. It runs a hell of alot better and I am very pleased!!!
It is good that you got it going. What did you do about the adhesive?
Just scrubbed and picked the brown stringy stuff out and put it back together. Boy it ran nice!
Looks great. I think I have the same carb (well, maybe not as dirty)...I have not had my off or apart (yet). Can you adjust the mixture at all on that? Mine seems to be running on the rich side and both plugs looked black and sooty. I'm wondering if I can just lean it out a bit? If not, I guess I'll be doing the same thing you did.
