Narrow vs. wide frame
I am looking for a snow blade for my 129. What I need to know is how to tell the narrow from the wide frame. I am sure I can modify the narrow to work as I spent a lot of years in a fab shop, but knowing what I am buying is important to. I let one go by a few months ago at a online auction for 85.00 or so, should have jumped on it. They are hard to find around here in central Michigan.
Russ |
You have a wide frame tractor. I moved your post to the implements section. I'm sure someone will answer your questions.
The wide frame subframe has a curl up at the back of it like this. Where the narrow frame is straight.
Mark 1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights 1967 Model 102- mower 1965 model 70 - weights,rear lift and spring assist Model 100 resto mod project, rear PTO, hydraulic lift QA42 snow thrower 42in front blade Grandpa's F-12 and Super M |
Just to add to what Mark has already said, the WF "arms" of the subframe also bend back together and get narrow at the end so that they can fit up under the frame on the rock shaft and the NF "arms" of the subframe are wide at the end and rest on the rods of the footrest.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
Michigan is full of Cub stuff. Maybe you can't find one in your backyard, 3 doors down.... but if you can't find a blade, you aren't looking.
Well, you are right there are none 3 doors down and in truth I have not had the time to look hard for one. I have a 2550 with a snow blower so the blade is not a high priority. Thank You all for the response. Russ |
They are quite plentiful in my area!! However, shipping would probably be cost prohibitive.
