Old 01-08-2017, 01:25 PM
Pigpuller Pigpuller is offline
Default Bedliner
has anyone on here ever rolled rustoleum bedliner on any thing let it dry than sprayed enamel paint over it. I was thinking of trying it on the topside of my mower deck the metal is pitted from rust just wondering if enamel paint would stick to it
Old 01-08-2017, 09:35 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Yes. You can paint it.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1210 1250 1415 1420 1440 1450 1535 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3205 7265
Old 01-08-2017, 10:34 PM
taylorjm taylorjm is offline
Depending what kind you have, I wouldn't recommend using it for anything but a bedliner. This is the kind I have used, and it has chunks of rubber it in and doesn't smooth out at all. Painting over it wouldn't help at all. It holds up well, but all you can do is paint in on, move the chunks around to smooth them out some, and leave it.
http://www.autozone.com/paint-and-bo...?checkfit=true
Old 01-09-2017, 09:24 AM
How did you clean the metal? Unless it's been sandblasted there's still rust and that rust will come back in no time, wire wheels generally don't do a good job Removing rust. Bedliner isn't designed to stick to bare metal, you will need to put an epoxy down first.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-09-2017, 09:32 PM
No, it's just the type of bedliner. It's like a thick rubber paint, with chunks of rubber in it.
