Old 03-27-2011, 04:20 AM
Guitar Guy Guitar Guy is offline
Default 38" deck repair
My deck has a small hole which should be easy to patch / weld.
It also has part of one of the arc shaped pieces behind the blade rusted away. Does anyone know how easy or diffficult this is to repair, and if this piece is very crucial to the airflow / discharge of the deck?
Thx, Josh P
Old 03-27-2011, 08:24 AM
Inactive Member
The rusted away part(s) are called 'baffles". The baffles in some cases, are still available from Cub Cadet, but rather expensive. A lot of guys have simply custom fabricated these baffles and welded them in. YES, for the best cut, it is better that they are there.
Old 03-27-2011, 01:38 PM
I just went to my steel pile and grabbed a piece of the appropriate width strap iron, bent it in an arc to match the remains of the old one, and welded it to the deck after removing all the old one. On my 42 inch stamped steel deck it made a huge difference. Watch the blade clearance as you weld it in, and remember some day you may have a brand new and wider blade so make enough room.
Hardest part of the job will be cleaning the weld area before you weld in new steel.
